cam help
Old 03-28-2010, 04:15 PM
  #21
low_life96's Avatar
Originally Posted by KDavis04ss
TR 220. i believe its 551 lift so all you would need is yellow zo6 springs. makes really good power in a 4.8 and still drives great. dont think you could go wrong with it
? tr220
Old 03-28-2010, 04:28 PM
  #22
low_life96's Avatar
here the cam im looking at
Comp Cams 212/218 LSx Cam "LOW LIFT"
Basic Operating RPM Range: 1,200-6,000
Duration at 050 inch Lift: 212 int./218 exh.
Valve Lift with Factory 1.7:1 Rocker Arm Ratio: 0.522 int./0.529 exh. lift
Lobe Separation (degrees): 114
Grind Number: LS1 XR265HR-14
Old 03-28-2010, 04:53 PM
  #23
PT's Slowest Truck
budhayes3's Avatar
The Thunder Racing cams have fairly aggressive lobes, so even though the lift isn't extreme, more seat pressure is required to keep the lifters planted on the lobes and prevent valve float. I'd run PAC springs with any TR cams...
(LS6 spring closed seat pressure=90#)
(PAC 1218 closed seat pressure=130#)
Old 03-28-2010, 04:56 PM
  #24
PT's Slowest Truck
budhayes3's Avatar
Great cam, proven performer and excellent daily driver, with or without a converter. Yellow LS6 springs can be used no problem
Old 03-28-2010, 06:11 PM
  #25
low_life96's Avatar
ok will that cam give a lil thump an sound like it has a cam??? or will it have to be done in the tune??
Old 03-28-2010, 08:00 PM
  #26
PT's Slowest Truck
budhayes3's Avatar
It won't sound nasty but you should be able to hear it in a 5.3...set the idle a little low and it will sound meaner...
Old 03-30-2010, 05:07 PM
  #27
low_life96's Avatar
whats the biggest cam i can go with? without having a stall??
Old 03-30-2010, 05:34 PM
  #28
low_life96's Avatar
with the tr220/220 .551/.551 114 LSA woud i have to run a stall an thunder racing cam good?
Old 03-30-2010, 06:42 PM
  #29
PT's Slowest Truck
budhayes3's Avatar
Biggest cam without a higher stalled converter is subjective, what may seem like a soggy bottom end to one guy may be totally fine for another. Me personally, I wouldn't run a TR220 in a 5.3 with anything less than a 3k converter, but that's just the way I like it
My cam works fine with the stock converter, but I'd actually like about a 2600 converter with it to get me into the meat of the powerband quicker. Many guys have run the 212/218 with the factory converter and been quite happy with it
Old 03-30-2010, 08:18 PM
  #30
low_life96's Avatar
i have a 4.8.. im wating something with some thump to sound like i have a cam an still drive it to work everyday an get great power out of it iv never messed with cams as u can tell by all my questions lol.
Quick Reply: cam help
