cam installed
cam installed
everything went well the only question is I dont know if this is the right section but since i did the cam I dont have lock up any more in the trans. my check engine light is on but thats probably misefire code from the cam. is it a tuning problem or a converter problem, i just put that converter in a week ago. anybody had this problem.
thanks
thanks
converter lockup is determined electronically, however if you are recieving a misfire code, the computer won't allow the converter to lock, which is probably your issue - so basically get the tune right and your troubles should be over
how long before I get lock up after I clear the codes. just worried something is wrong, I cleared the random misfire codes drove it home ony about 5 miles but no lockup
the TC will go into lock-up after ~3200rpm without a detected misfire. so if you drove it say at highway speeds for a few minutes it should go into lock-up.
ask allen to bump up the misfire thresholds and that should help out.
Originally Posted by ProStreet83C10
all i know is if your SES light is blinking shut your truck down because whatever is going on could damage your engine.
just scan the codes to be sure nothing else is coming up, if it's a random misfire you can ignore it until you get it tuned, cams tend to set off a random misfire so don't sweat it...
My random misfire light is always on from my cam, but I've never seen it flash, except a long time ago when I drove through a puddle with a frayed plug wire. You must have some serious misfires going on there.
