Cam, Intake, Headers, Coils, Gear Ratio
Old 05-07-2014, 07:38 PM
Ricksilvy's Avatar
Stock coils work the best.
Don't go over 220 duration on cam and you will be fine. But with a good tune you should pass.
I'm running Jba shorties for the same reason, check points.
I did noticed an improvement in the mid range with shorties.
Old 05-07-2014, 07:58 PM
craigsix's Avatar
i would just use stock manifols with hiflow cats. the fast lsxrt is too hard to tune with a performance cam. go with a tbss and 90mm tb. i got my tb p@pd for $80.
Old 05-07-2014, 08:00 PM
craigsix's Avatar
i would go with a comp low lift cam also
Old 05-07-2014, 08:29 PM
99silvy's Avatar
Ill probably go with the texas speed 220r since iv seen a lot of people say good things about them. My tb is cable driven do they make one for its iv seen other companies around 2-300 bucks for them.
What about the holly intakes are they any good? I just want to gain as much performance as I can from these mods without having to get drastic and rebuild a whole new motor. While im doing the cam I want to finish it off with the new intake manifold and change the knock sensors while im there.
chopperloco
07-10-2016 10:45 PM
Noah Burns
10-05-2015 06:46 AM
GrooveCityZ71
08-31-2015 12:05 PM
Castro45
24
07-31-2015 07:13 PM
Ketis
07-23-2015 12:37 PM
Quick Reply: Cam, Intake, Headers, Coils, Gear Ratio
