Cam to maintain low end
Old 08-14-2009, 11:36 AM
PT's Slowest Truck
budhayes3's Avatar
Check out the cam in my sig, good torque off idle and pulls to just over 6K. Doesn't require a higher stalled converter, but a mild one wouldn't hurt. If you're planning a mild converter (2600-3k), I'd recommend the proven Comp 212/218.
Old 08-14-2009, 01:07 PM
NateZQ8's Avatar
Originally Posted by 00Silv4.8
I have a Lunati 221/221 .884 114 in my truck right now. I would tell you to get it but on a 112. Mine doesnt hit till about 2000 or so, in my 4.8 it was about 3k. Other than a little loss of low end the cam has been great, pulls like an SOB up top and doesnt quit
Wow.......884 lift???
I would say anything with a short duration (Less than 230) and high lift would be ideal for low end TQ. Also if your thinking heads, any smaller volume intake head (Stockers, AFR 220's, TFS 215's) will add velocity to the air moving through the ports and you will pick up some TQ.
Old 08-14-2009, 02:22 PM
12 Second Club
Hawaiian_Built's Avatar
I'm leaning more and more towards the hight lift 212/218. I wish it came on a 114 though. How bad would it be without the proper stall? I
Old 08-14-2009, 04:59 PM
12 Second Club
Saw this in the Classifieds, pretty close to what I was looking at but I dont know anything about reverse splits
.564 .562 220 218 114 LSA
How would this work?
Old 08-14-2009, 05:35 PM
03 BLACKOUTSSS's Avatar
that would work similar to the cam in my sig. Real tq monste off idle, pulls real hard from 3500 to 6000.
The reverse split is typically not accepted as a good idea because the intake ports flow much better than the exhaust ports do on LS motors (most motors for that matter). The reverse split is designed, from what I understand, maximize the forces at work in the intake, heads and cylinders. Depends on several factors, intake runner length, which harmonic order the intake itself falls into, things like that. It has to do with intake air pulse rates and increasing the Venturi effect. Basically, reverse splits usually result in elevated Volumetric Efficiency, which causes higher dynamic compression ratios (more power). The Venturi effect combined with the vaccuum created in the cylinder when the exhaust valve opens results in VEs rising (it effectively "sucks" the air fuel mix into the chamber for the next one. Combine that with a thinner head gasket which reduces quench area (the area that is between the head and the block after heads are torqued) which in turn creates a less turbulent, more efficient flame front during combustion, again, increasing TQ.
Someone call me out if I am off base a little bit. Hope this helps.
LARRY01Z28
08-01-2015 10:15 PM
OLD BULL
08-01-2015 05:00 PM
bgray
07-23-2015 10:56 AM
jrplz
07-09-2015 12:07 AM
Quick Reply: Cam to maintain low end
