Cam to maintain low end
Wow.......884 lift???
I would say anything with a short duration (Less than 230) and high lift would be ideal for low end TQ. Also if your thinking heads, any smaller volume intake head (Stockers, AFR 220's, TFS 215's) will add velocity to the air moving through the ports and you will pick up some TQ.
The reverse split is typically not accepted as a good idea because the intake ports flow much better than the exhaust ports do on LS motors (most motors for that matter). The reverse split is designed, from what I understand, maximize the forces at work in the intake, heads and cylinders. Depends on several factors, intake runner length, which harmonic order the intake itself falls into, things like that. It has to do with intake air pulse rates and increasing the Venturi effect. Basically, reverse splits usually result in elevated Volumetric Efficiency, which causes higher dynamic compression ratios (more power). The Venturi effect combined with the vaccuum created in the cylinder when the exhaust valve opens results in VEs rising (it effectively "sucks" the air fuel mix into the chamber for the next one. Combine that with a thinner head gasket which reduces quench area (the area that is between the head and the block after heads are torqued) which in turn creates a less turbulent, more efficient flame front during combustion, again, increasing TQ.
Someone call me out if I am off base a little bit. Hope this helps.
