View Poll Results: Witch cam would you want to use.
Lunati 60510
75.00%
GM Hot Cam
25.00%
Voters: 4. You may not vote on this poll
Cam Options?
Cam Options?
I know this is done over and over again, but if you were to use one, witch would it be. Based on cams only, dd, LS1 stock block, 862 stock heads. I know there are better cams. Wondering if the more duration with the stock heads would be better or the shorter and a little more lift. The Lunati has a ramp rate of 50 if anyone wanted to know.
Lunati 60510 212/218 .531/.531 113
Hot cam 217/228 .525/.525 112
The TB that in mine sig. I'm just swapping in a rebuilt stock short block LS1 and using everything else on the truck. The lunati is in my truck but I can get the hot cam from my boss at work. I was just thinking it the truck had more duration it mite act like I had better flowing heads. I don't think the power will be that much different from to two and the lunati will give me more torque witch I want. Not spinning the truck past 6k anyways. Any thoughts will be nice. To all- please vote anyway.
ARC
57
02-21-2022 10:54 AM
oharajo
07-18-2015 09:24 PM
04BlackGmc
07-16-2015 04:10 PM
