cam purchase assistance needed
#21
Lift is not as pertinent to LS motors as is duration. Overcoming big lift cams is a spring change away.
Depends on what you want from the cam and how you use your truck. Either of those will need converter and are going to have a dead spot under 3000 rpm. Not knowing everything about your setup and goals, I would recommend the 224R on a 112. Feel free to give us a call or shoot us a PM for pricing and to further discuss your options.
- Beau @ TSP
- Beau @ TSP
#22
Marine, when I talked with them yesterday... since I am in Hawaii, they really wouldnt assist with any discounts because of the shipping cost.
With the 220/220 cam I was told I didnt need a stall, but if I went anything larger I would. Also, I am looking to change the push rods, lifters and truions. I am still looking for a set of 243's or 799. Trying to make about 400 good hp
#24
im with this guy ^^^^
#27
FormerVendor
400 can be made N/A from a 5.3L. It just takes the right heads/cam combo. Instead of replying to each individual post, I am just going to recommend giving us a call and we can discuss further with each of you options and pricing. Thanks
- Beau @ TSP.
PS. Long time no talk Stewart. How's the S10 coming along?
- Beau @ TSP.
#28
The 5.3 generally puts out about 35ish at the crank, with the 220r cam gains are around another 35ish. 243/799 heads should net about another 35... so realistically thats over 420ish at the crank
#29
11 Second Club
Let's just say trying to get 400 hp to the wheels with a 5.3 means a lot money and a lumpy cam that won't be all that streetable. Certainly not achievable with the cams being discussed so far. Don't get hung up on numbers.
