Cam question
#31
because alot of times when its cold out and the truck hasnt been run in a few hours, I will have a real loud lifter tap, I can actually see the oil pressure guage ticking back and forth (around 40psi) as the lifter taps. sometimes it only takes a little rev or a minute of idleing to stop the tap but sometimes it will tap for goddamn 10-15 minutes untill the oil works its way into there. Its fukin embarrassing sitting there tapping away in a parking lot. I've tried different oils, and expensive filters with the backflow prevention valves on them and nothing seems to work. so I decided to just replace the lifters and say fugetaboutit
#36
As far as the lifters go, whats your opinions on my lifter tap problem? it seems like the older the oil gets, the less it taps. fukin wierd, im already running 10w30, should I go with a lower viscosity, or an additive? are the lifters hard to replace? how much would a good quality replacement set run me?
#37
#38
Laid Back
My brother's 4.8l has a tapping lifter or two. If we run Castrol GTX 5W-30 in it the lifters barely tap at all. Mobil 1 5W-30 is a different story. It makes the tap loud as hell. I've switched back and forth between the two motor oils multiple times and seems like the conventional Castrol is always quieter.
#39
Hmm, I think i'll try the 5w30 and see how it works. I loose about a half gallon of coolant about every 1-2 months so I was thinking of doing the head gaskets anyway, so the heads will probably be out either way. I get no oil in my coolant and no coolant in my oil, my heater dosent smell like coolant when its on, and the coolant isnt leaking outside of the motor anywhere.
so does this sound like a head gasket issue? is it common? its done this for a few years now but every time I smog it it passes with no problem/issues whatsoever (although I dont know if burning coolant out the exhaust would make you fail anyway)
#40
PT's Slowest Truck
