cam question
cam question
I have a 2001 silverado with the 5.3 its tuned has a cai and exhaust. But here lately I have been wanting to do a little more I found a medium size garret turbo i am buying (family deal) and before I do that I am wanting to change the cam what lift duration can I use on stock valve springs? i dont want anything radical just a little bit more than stock. also do i HAVE to remove the heads to change the cam? thanks
They are in cups, once you pull the rockers and pushrods out, all you have to do is spin the engine over a couple of times and the lifters should stay held up by the cups. They make a tool that fits in two holes in the front of block to make sure they don't fall, but you can just use good sized dowel rods.
bbowerman
07-26-2015 10:57 PM
