cam recommendations for a 4.8?
4.8 with 1 3/4 long tubes & a servo, want to put a cam in it just not sure what size to go with i dont want to build a monster just a fun aggressive daily
LS1Tech Sponsor
The community can help you pick a cam, but we will need some more info.
What is the year of the truck and is it RWD or 4WD?
Does this have VVT and AFM/DOD?
If you have VVT and AFM are you wanting to keep that or are you getting rid of it?
Are you wanting a drop-in cam without changing valve springs? Do you know the mileage on the engine?
Are you using the stock torque converter and gears? Are you willing to change those?
The more info you provide the better we will be able to provide a camshaft recommendation.
Truck Sponsor
The following 2 users liked this post by madmann26:
00pooterSS (11-15-2019),
dantheman1540 (11-15-2019)
The following 2 users liked this post by ZO6Ted:
@stock48 @03sierraslt can make a great cam recommendation for a rockin idle, cut on a 106-109 LSA, have great off idle pull but more times than not, guys will go get a ms4 cam and wonder why the fkn tires won’t roll over with their 2k stall.
Tell me when I’m wrong.
The following 5 users liked this post by madmann26:
1slow99 (11-15-2019),
dantheman1540 (11-15-2019),
RedXray (11-19-2019),
stock48 (11-20-2019),
ZO6Ted (11-15-2019)
