View Poll Results: What your choice
BTR truck norris 212/22X, .552/.552, 107 LSA
16.67%
TSP stage 3 low lift truck cam 216/220 .550/.550 112 LSA
33.33%
Cam Motion stage 2 truck cam 206/210 .553/.553 115+5 LSA
16.67%
Cam Motion titan 2 cam 212/210 .553/.553 112 LSA
33.33%
Cam Motion lil lope cam 216/224 .553/.553 108 LSA
0%
Voters: 6. You may not vote on this poll
Cam selection advice
#22
@1FastBrick I think that the idle is extremely tune dependent. My 6.0 with the same cam has a pretty good lope.
#23
Custm2500's Rude Friend
I am sure if you add timing it will lope more. As it sits only a few people have done a double take and asked if it was modified.
shakenfake (07-03-2024)
#24
Adding timing to reduce lope? Usually adding smooths it. Or are you just adding some to adjacent cells in order to get more of an rpm swing, (not increasing the whole cell range in the idle area)?
#26
LS1Tech Sponsor
We prefer engine/chassis dyno tests to compare cams. The below video from Holdener has cams in the range the OP is looking for including some on the OP's list. This is an L33 5.3 with a FAST intake and long tube headers. The SUM-8728R1's graph is very similar to the rest in the test. They all peaked around 6,000 rpm with 44Xhp and 42Xtq. With the cams in Holdener's test, you wouldn't be able to feel the difference from one to the next.
#27
Summitracing (07-11-2024)
#28
LS1Tech Sponsor
@shakenfake,
Let us put down the silver spoon and go fire up the engine dyno with a Supercharged Edelbrock 416 stroker hooked to it
Kidding aside we know you were 100% aware the software dyno results aren't gospel. This was a friendly reminder of the third-party test for cams similar to what the OP and many others on this forum are interested in
shakenfake (07-11-2024)
#29
