cam specs.
cam specs.
does anyone know the cam specs on the 1999 5.3L. also the specs on the 2000+ 5.3L.
does the 2000+ 5.3L use a 6.0L cam? is that the only difference between the 1999 engine and the 2000 engine?
thanks yall....
what kind of cam is everyone getting? i want a streetable cam. taking suggestions.........
thanks yall....
Re: cam specs.
OK OK OK
1999
12560966
lift (exh/inl) .466/.457"
centerlines(exh/inl) -118/113
separation 115.5 deg
duration @ .050"(exh/inl) 193/194 same
duration @ lash (exh/inl) 328/328 same
2000
12560967
centerlines(exh/inl) -112/116
separation 114 deg
1999
12560966
2000
12560967
separation 114 deg
Re: cam specs.
hey, with those specs what makes the 99 lose power up top, it has a higher lsa than the 2000 cam and same lift/duration but still makes no power on the top end <img src="images/icons/confused.gif" border="0">
Re: cam specs.
Back when I was looking at doing a cam swap, I got the numbers for the 99, 01 and 01 Escalade. That was a few months ago though, I'll see if I can dig them up. For some reason the numbers are very hush hush, I could barely get the base numbers of the cams <img src="gr_sad.gif" border="0">
[ February 07, 2002: Message edited by: 99GMC ]</p>
