Cam and stall Converter
i have the tci 3000 streetfighter its real loose which is my only complaint but it stalls up like a bastard and i say go for he 3200 i wish i too would have gone bigger after i got mine installed your gas mileage is gonna drop anyways might as well make it worth it but have not heard anything about the raptors but i have driven a couple of yanks and they are primo good luck and keep us posted
Originally Posted by gonzo 6.0
Ls6 springs is an excellent choice for that cam.
I see you have that exact cam, do you like it? Did you feel good power???
I spoke with the guys at Comp and they said thise springs are perfect, thanks!!
As you can also see it's in a 6.0.i bought the cam used and went with new LS6 early "blue springs" the motor has been in there over 2 years & lots of miles and maybe an average of 20-30 WOT blasts per fill up.Everything have been flawless from bumper to bumper.The valvetrain in more quiet than the 5.3 was,I think because I shaved .020 off the heads which tightened up the valve lash.It has a lobe to it,and it will be more pronounced with a 5.3 it will lope more and make more emmisions which could cause you to not pass smog.If i were to do mine over again I would go with more lift,something like 220/550 114LC and LS6 yellow springs.We have no testing were I live.What I would recommend you do is save your dough and find a good take out 5.7 LS1 longblock slip that in with a either a early LS6 cam or a custom grind like a 208/214 550 114-115LC with LS6 springs.And a good tune and it should pass DEQ and haul ***.To try and answer your question
Yes it makes great power,I did have to raise the idle,you need to ask around to see if anyone has passed smog in a 5.3 with this cam.
LCHEE
10-24-2020 04:10 PM
Castro45
24
07-31-2015 07:13 PM
