Cam suggestions?
Old 02-07-2003, 10:29 PM
pony killer's Avatar
Default Re: Cam suggestions?
just remember opinions are opinions try a few different cams to see what best performs for you teir relatively easy to swap if you have the time just my opinion on this matter. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old 02-07-2003, 11:51 PM
11 Second Club
Texas Terminator's Avatar
how about this one?
HYDRAULIC ROLLER, Fair idle. High performance cam. Lots of mid-range torque and upper horsepower. 2000-5000 282°
287° 218°
221° .526"
.534" .309"
.314" 116° Sep
112° Int C/L -03°BTC 41°ABC /
50.5°BBC -9.5°ATC
Old 02-08-2003, 12:10 AM
BigTex's Avatar
Cant tell the numbers - Is that a 218 intake / 221 exhaust on a 116lsa? The 116lsa would be good for boost.
Old 02-08-2003, 02:54 AM
LS1Tech Co-Founder
Nine Ball's Avatar
218/221 is pretty small for 408ci. I had a 221/221 in my previous 382ci and it idled like stock.
408ci-415ci, I'd look for a cam with an intake duration in the 232-237 range. Exhaust durations will vary depending on what you are building. For that blower, I'd probably add 8 degrees to the exhaust duration to split from the intake. 114 LSA is plenty of overlap on a split pattern cam.
the 232/237 cam is available from MTI, called their "R1" cam and is very popular. www.MotorsportTech.com
Otherwise, you could have any of these sponsoring shops order you your own custom camshaft, they cost the same as their proven camshafts. You basically pick from a catalog of their different lobe designs and make your own combo. Set your own LSA, and determine how much advance to grind into it.
I'd choose the R1 for your setup though. If you order it, just specify that you want it on a 114 LSA, its available either way. (112 or 114)
-Tony
Old 02-08-2003, 09:13 AM
11 Second Club
sorry about the numbers, i tried to copy and paste part of it and it obviously did't work out. oops! it is a 218/221, 526/534 with 116 lsa. it is a lunati piece. check it out here http://holley.com/HiOctn/ProdLine/Pr...CC/Chevy6.html there are some more radical profiles there too. i can get a cam from them when i order my stroker kit for like $280. i keep forgetting about the larger cubes and the end result with a larger profile. <img border="0" alt="[bang head]" title="" src="graemlins/gr_banghead.gif" />
Old 02-08-2003, 09:19 AM
11 Second Club
just looked at that R1. not bad. i wish it had a little more split to it though. btw, does anyone have that FEEAKING MONSTER 427 that they have?!! the stroke on that thing is insane! just look at the bottom side picture of it!
Old 02-08-2003, 09:38 AM
BigTex's Avatar
Here:
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=2401769565
You could change to an aluminum block to reduce weight and run cooler.
Old 02-08-2003, 09:44 AM
11 Second Club
too bad it's the wrong bore, that's cheap!
JordanH
08-08-2015 07:59 PM
LARRY01Z28
08-01-2015 10:15 PM
steves86ta
07-28-2015 10:21 AM
WICK3DxGATA
07-21-2015 06:59 PM
Quick Reply: Cam suggestions?
