Cam swap
Old 01-23-2010, 08:38 PM
  #21
SLOXCAB's Avatar
thats where is he based out of but he travels all over the country. you can get a street tune for around 250
Old 01-23-2010, 08:44 PM
  #22
dirt track racer 81's Avatar
Originally Posted by wwardd
I read the specs on the 5.3 HO crate and they did a cam and piston change and hit 330.The cam gm uses for this engine is the LQ9 cam from late model 02-up. I am not going to do piston change but was thinking maybe a head change like LS7 heads. Like I said maybe i am wrong but I do have another ? I can't have LT headers due to emissions but r shorty's worth it I have heard mixed results. Thanks
ls7 heads require a 4.080 bore. l92 heads require a 4in bore. what you are talking about is rated at flywheel, stock you are making 220-250 rwhp depending on the type of dyno. all the bolt ons and a decent cam willl get 300-340 depending on cam, mods, and dyno
Old 01-23-2010, 08:51 PM
  #23
wwardd's Avatar
Cool thanks
Old 01-24-2010, 04:17 AM
  #24
02'Z71ONDUBZ''s Avatar
Try at least reading the stickies in the GM Performance section if your not going to search... https://www.performancetrucks.net/fo...d.php?t=414374 That link could give you all the info you would need to meet your goals. People on this site have spent lots of time putting threads together to make information easily accessible for specific questions like yours. Use it to your advantage.
Old 01-24-2010, 11:22 AM
  #25
03 BLACKOUTSSS's Avatar
Originally Posted by 00ChevyScott
wwardd, somebody has been telling you stories buddy....
Do yourself a favor and just read, read, read, and read. And then read some more, because you have A LOT to learn. I would suggest not buying any parts or taking any steps in modding your truck yet until you have a very good understanding of what these parts do and how they effect your engine and performance. Make sure you also understand the supporting modifications that must be done before and after changing cams, etc.
So to sum it up
DO NOT BUY ANY PARTS OR MAKE ANY DECISIONS UNTIL YOU READ THREADS ON THIS FORUM FOR AT LEAST A MONTH. There is a lot of knowledge and experience around here, and you will learn very valuable information, and very useful steps to follow. We will save you money on mods that are proven not to work or be worth the money, but don't expect to spend less than $5-6K if you're looking for 350-400 horsepower.
What? Where's Scott? What have you done with him?
The 5.3HO crate is a joke....
Oh, there you are, whew! Glad to see you're okay
OP, READ READ READ. When you are done reading, find another thread and read some more. You may not understand all of what you are reading, but you will have some fairly specific questions which everyone hear is more than happy to answer, as opposed to the "how do I make 400 rwhp with a 5.3L and $275 to spend?" question that has been asked over and over.
As for your goal, is it possible...absolutely, is it easy...no, cheap...HELL NO. But when its all done (its never done), when you wax your first mustang, and you see that look on the drivers face like you just kicked his mother in the teeth, it makes it all worth it.
Old 01-24-2010, 08:14 PM
  #26
wwardd's Avatar
Thanks guys ya ll been a big help.
Old 03-11-2010, 02:11 PM
  #27
Registered User
sleeper50's Avatar
what kind of h.p increase do you think i could get doing that...how much $$ to get this done?
Old 03-11-2010, 02:31 PM
  #28
Registered User
sleeper50's Avatar
hi i have a 03 silverado 5.3 lm7 or? not sure how to tell?
so far i have put a cold air induction in, high performance plugs and wires, flowmaster 40 series exhaust, 373 gears and 3way high performance chip..havent had it dynoed yet..Just curious how much hoarse power do you think i have increased so far?
Old 03-11-2010, 02:33 PM
  #29
Wearin' da big hat
00ChevyScott's Avatar
A 3way high performance chip? I'd say you're at 500 hp at least.
Old 03-11-2010, 02:38 PM
  #30
Registered User
sleeper50's Avatar
i wish lmao
what about adding a mild cam and port and polish heads?
Quick Reply: Cam swap
