cam swap gasket package?
Old 06-18-2004, 11:21 PM
bigguy75inches's Avatar
Default cam swap gasket package?
hey, just wondering what all i need as far as gaskets go for a cam swap? i also need a crank bolt???
Old 06-18-2004, 11:45 PM
BigTex's Avatar
I didn't change any last time on my SS. But on my higher mileage 99 truck, I needed new waterpump gaskets. I went ahead and changed out the crank front cover seal, but not the timing cover gasket. Those are the ones you may need.
Old 06-19-2004, 04:06 AM
OBXMarine's Avatar
For my own benefit, I threw on some new ones (water pump, timing cover, and crank seal) since I was already in there. I've heard several times you can reuse the origianl ones unless it's a high mileage engine. I'd definately get a new crank bolt. They're not much and it's your lifeline.
Old 06-19-2004, 07:32 AM
Formerly one92rs
one03sierra's Avatar
Talking
i used the scoggin dickey cam install gasket kit.
Old 06-19-2004, 10:10 AM
ktmrider's Avatar
Yep, SDPC will take care of ya. They have both cam or cam/head kits. Both include all the needed gaskets and the crank bolt.
In reality, the excellent rubber coated crush style gaskets that come stock are reusable. The crank bolt is cheap insurance, but I understand many folks do not replace them every time.
I paid around $250 for my cam/head gasket kit and will get better peace of mind. No point in spending $400+ for your cam stuff and not replacing gasket materials.
Old 06-24-2004, 01:12 AM
Mr. Sandog's Avatar
Where do you get the crank bolt from if you already have the gaskets?
Old 06-24-2004, 06:30 AM
Formerly one92rs
Talking
get the crank bolt from the dealer.i have gotten a couple and they are around 8 to 10 bucks. part number ius in the part# thread in lounge.
Old 06-24-2004, 12:04 PM
GREGGO's Avatar
Didn't change a thing. 6k on it and no problems.
Old 06-24-2004, 12:10 PM
Mr. Sandog's Avatar
I see two number for the crank pulley bolt:
12557840
11516618
Wonder which one is correct?
Old 06-24-2004, 12:43 PM
marc_w's Avatar
Does GM make the "long" crank pulley bolt, or is that something special out of a good hardware store?
(The long bolt is used to help remove/install the pulley)
Quick Reply: cam swap gasket package?
