Cam swap parts, a few questions..
Custm2500's Rude Friend
Since a factory 5.3L is around 9.5:1 with the factory heads @ 61.5 CC chamber and the 243 heads have around a 64.5 cc chamber, You would have to mill the 243's around .030 just to get them back to factory spec to maintain 9.5:1.
The more you mill the heads, the more you comprimise the deck for forced inductions applications.
.030 is about the most you can mill a factory head before you start running into Intake fitment issues...
Now if you open the motor up and stick a flat top 4.8L piston in there You would barely have to mill the heads.
Dont believe me??? Look up the factory L33 option. Its an aluminum 5.3L with 4.8 flat top pistons and 243 heads from the factory. Compression is around 9.9:1
HTH
HTH
HTH
HTH
Thanks guys
Some of the 4.8/5.3 heads had a notch in them that hindered one from using MLS gaskets. I'm not sure if any of the 243's were notched or not, but that is definitely something to be mindful of.
Do you already have the 243's? If not, how much are you planning on spending on a set? The reason I ask is that by the time you find a set and have them rebuilt/milled, you may be able to pick up a good set of 862/706's and have a mild port job done.
No its not too much at all but all im planning on doing is the heads and cam..doing a head and cam swap is one thing but pulling the entire bottom end and all that is another thing.. if i was gonna do the pistons and all that i would probly just go ahead and do my 6.0 swap.. I've thought about it more and my best bet is to probly just stick with 5.3 heads cause i wont have to mill them hardly at all to get my desired compression ratio..
Since ill probly just stick with 5.3 heads my main concern is i want alittle better flow but will a port job hurt the bottom end power any? I know bringing the compression up will help bottom end too i just dont want to lose any from porting the heads..
Thanks guys
Thanks guys
The 806 early premeter valve covers had the same issue with the nothced area
Here is were That info can be found. Gen III GM Small Block: Engine Builder
243 heads did not have that issue.
Here is a discusion we had pertaining to MLS head gaskets. https://www.performancetrucks.net/fo...gasket-491846/
Thanks guys
Thanks guys
