Cam Swap suggestions
A larger cam and higher stall will make a huge difference!!! What gears do you have now?
My plans for my 4.8 are a 220/220 cam with a 3000-3200 stall, and 3.90 gears. That should be enough to hold me over till I get the 4l80, and the 6.0 built how I want it, which should be enough to hold me over till I get the 427 built![The Jester](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_jest.gif)
Assuming you have at least 3.42 gears, you should be ok with a higher stall and bigger cam. If you have steeper gears (lower numerically) you may want to step up to 3.73's or something even lower. Im putting 4.10's in my CC but Im running a tall tire on it.
i have 3.73 gears but im on a 305 35 r24 tire... which is like a 33" tire..lol yes i know the rims r not performance but i like to have it look nice and run good also. i put the stockers when i go to the track.. 265 70 r17.. i like my cam but i might go bigger soon.
Either way, a bigger stall and cam will help it move out quicker. The cam, stall, and gears will make it even better.
![Shiftin' Fool](https://www.performancetrucks.net/forums/images/smilies/3.gif)
13 Second Truck Club
i am still stock 3.42 gears ...shifts into 3rd at the 1/4 mile
3.42s are hurting my 60ft times 2.0 on drag radials
didnt you say you were 4x4 thats double the price for gears!
I am willing to put my baby cam against a 220 cammed truck any day!
If i was you go 3000 stall and if you recammed it wouldnt go to big so it still has lowend grunt
I sold someone my damn tru track and now I need it
![Guns](https://www.performancetrucks.net/forums/images/smilies2/guns.gif)
![Cry](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_cry.gif)
Sounds to me that you just aren't happy with your results. I would do as everyone else has suggested with changing out the converter, then if thats not enough I would throw some 4.56 gears with a 22, finally if that doesn't get you were you want to be then change out the cam for something bigger. Because by then you'll have all the tools in the truck to get what you need out fo the cam.
sorry typo im an 9.65 on the 1/8th....soooo sorry... and how do u shift into third on 3.42 i have never shifted into third. now im on 3.73s and i still dont shift into third im shifting at 95mph out of second... well im going to change the tq converter next.. may b do 4.10s would also help..
