Cam Swap suggestions
#23
Slow n low 4.8 I don't know if u told me but what size gears do u have and what size tire r u running. If I could get a 13.8 with my cam I won't change anything..I'm on 3.73s with a 265 70 17 tire. And I guess I'm getting the converter next. So u say 3000 not 2600-2800? Thanks.
#24
13 Second Truck Club
i wanna say it 29.5 inch tall tire
And on the stall i say 3000 yank i love my yank its tight and works good with this cam
i am wanting to go 3.73 to get some better 60 fts than 2.0
I only made 2 passes with my setup 13.8 1st pass and 13.9 2nd pass
#26
i wanna say1-2 shift 6300 and 2-3shift 6100 i maybe off by 100 rpm not sure been a while since we did shift points
Are you hitting the rev limit because of slippage or tunning issues?
#27
i believe its slippage atleast thats what the tuner told me. mine is set to shift at 6100 at 40mph but for some reason i feel something is wrong.. its hitting the rev limiter at 6350 and shifting at like 52-53mph or thats what i see when im looking at the speedo.. o and i just changed my tires to 245 70 17 today but havent adjusted to the new size. the ones i had were 31.6 tall the ones i put r 30.5 and the when i looked up urs they came out as 28.8.. so maybe thats y ur shifting into third in the 1/4 mile..
#28
#29
yea i understand that part. my tuner said it should be shifting at 40mph which is kind of weird because before on my 3.42s i was shifting at 6200 at 55.. now i know i put 3.73s and its said to shift at 6100 but i dont think that small jump in gears should drop me to shifting at 40.. im going to double check with justin and double check the shifting
