cam swap trouble
Completed everything... Truck won't start.. everything is connected.. everythings in its place.. when I turn the engine, it sounds like a suction pump.. help???
Timing off? Dot pointing at dot and dot vertical with dot. Did you turn the crank after installing the timing set to make sure the dots were where they should be?
