cam swap trouble
#24
#26
Did you not turn over the vehicle by hand a couple times? Take everything apart, line up the dots properly, turn the engine over by hand (take plugs out) and listen to any "abnormal" noises. This is a quick way, but not the most efficient. Also check compression on each cylinder with plugs out.
HERE: http://www.ls1howto.com/index.php?article=23
#27
I looked at the write up on ls1howto.. but I think the timing migjt be off a tooth or two.. I lined it up as much as possible, but not exactly.. I doubt I bent a valve.. I'm sure you would be able to hear something if I did.. if all went to ****, I'm getting my tax return soon.. hello 6.0....
#28
If it was off by a tooth or two it should have still started. If it didn't sound like a mess cranking up you should be fine, just double check it before putting it together. Just hope your not thinking the cam dowel is what you should be lining the crank up with.
Watch from about 2 minutes:
LS Cam Swap pt6 (timing gear install, replacing front crank seal & timing cover prep) - YouTube
#29
Cam sleek is the fourth hole on the sprocket.. the dot is near the edge with the teeth.. it smelt like gas when I cranked it.. that's the only abnormal thing I could find
