cam timing - 1 tooth = how many degrees?
Old 08-12-2012, 04:33 PM
Custm2500's Rude Friend
1FastBrick's Avatar
ugh. my first attempt to move only the cam gear 1 tooth was a failure. something on the crank gear must have moved. i'm back dot to dot and reading 100. guna give it 1 more shot.
Whats taking so long???
Old 08-12-2012, 05:10 PM
TXsilverado's Avatar
1 tooth is definately more than 8. more like 15-16. why cant things just work the way they're supposed to? moving the cam gear 1 tooth clockwise sent the ICL to about 85. after some reading, the fact that my ICL is at 100 means that it is advanced 10*. i need to retard it 6*
Old 08-13-2012, 10:14 AM
i just called up howards cams. they picked up on the first ring and told me to send that cam back to them ASAP. i said it wasnt a big deal as i wasnt in any kind of huge hurry and he said "i am. i dont like to see incorrect parts and i want to fix this ASAP." Definately the kind of customer service everyone should strive to provide. just wanted to give credit where it was due.
Old 08-13-2012, 10:28 AM
pewterliftedz's Avatar
Dam that's some good service stew... Can't wait to this lil bastard running lol..
Old 08-13-2012, 10:32 AM
you and me both. just about everything is here. the correct cam and transmission rebuild are the only pieces of the puzzle missing. oh and the wheels/tires and radiator lol. just another 2500-3,000 worth of shiz
Old 08-13-2012, 02:45 PM
05HD1500's Avatar
its because the cam spins once to the crank spining twice so 8* (one tooth) at the cam is 16* at the crank
i think i said that right
Old 08-13-2012, 02:48 PM
oh well. hopefully the new cam sits the right way when dot to dot. i think the odds of the aftermarket cam being off is higher than the odds of the OEM crank or cam gear being off. maybe i'm giving GM too much credit
Old 08-13-2012, 02:51 PM
1FastBrick's Avatar
Nice to hear!!! It is possible that it was set up wrong on the machine. It does happen I have watched the process from start to finish and as simple as it is there are a lot of little things that have to be done correctly.
Glad they want to fix and have great customer service unlike other cam companies...
Old 08-13-2012, 05:34 PM
Poboyjohn's Avatar
this is why i will prob just pay someone to do mine an im a mechanic lol im just lazy an get burnt out on working on cars but love driving the **** outa them..
Old 08-13-2012, 05:41 PM
Jake Wade's Avatar
Are you positive you found true TDC before degreeing? I am sure you did but it is a very important 1st step to obtain correct readings.
Quick Reply: cam timing - 1 tooth = how many degrees?
