cam timing - 1 tooth = how many degrees?
Old 08-14-2012, 01:20 AM
  #31
Custm2500's Rude Friend
1FastBrick's Avatar
the cam is out and boxed up ready to go back to howards tomorrow. i'm sure they have a way of measuring it and confirming that it is off.
Keep us posted!
Old 08-14-2012, 07:41 AM
  #32
Gadgetized's Avatar
...and measured .050 from peak lift on both sides.
I think this might be your problem. The open and closed side of a lobe can have different ramp rates.
I assume you have covered the basics like only turning it over in a clockwise direction while looking at the crank. The chain isn't designed for a tensioner, and you are not running one, or vice versa?
If it is still off, you might be able to get an offset keyway for your oil pump/cam gear, or even get an offset keyway cut in the gear.
Just a couple thoughts.
Old 08-14-2012, 09:31 AM
  #33
TXsilverado's Avatar
yes, it was turned clockwise when measuring at .050. even if the chain was designed for a tensioner and i removed it (or vice versa), 6* off is huge. not something a tensioner would be able to dramatically change (in a LS motor anyways).
Old 08-14-2012, 11:44 AM
  #34
Gadgetized's Avatar
I'm not even sure if the chain is different, just throwing it out there. Yeah 6* is pretty big. Hopefully it is the cam, that would be the best fix.
Old 08-21-2012, 04:06 PM
  #35
just got off of the phone with john from howards. he told me that they measured it out and i was absolutely right. he apologised and said it should have been caught in QC and said they will have me a fresh cut out by Friday. gotta love good customer service.
Old 08-21-2012, 05:24 PM
  #36
Gadgetized's Avatar
Very good news.
Looks like I better check mine when I put it together.
Old 08-23-2012, 09:12 AM
  #37
i have never measured my cams in the past. just went dot to dot and ran with it. i will be checking for now on.
ARC
57
02-21-2022 10:54 AM
OHsixLS3
12-27-2016 09:30 AM
Three6GMC
11-05-2015 10:02 PM
Tig
09-30-2015 07:39 PM
GRRR65GTO
07-10-2015 08:27 PM
Quick Reply: cam timing - 1 tooth = how many degrees?
