Cam vs. Brakes Question
Old 05-11-2007, 10:37 PM
Default Cam vs. Brakes Question
I have a 228 cam and just noticed that I am having some brake issues. The pedal is very soft.
I also have Baer Eradispeeds in the front with stainless steel brake lines.
I either have air in the lines or my cam is affecting my brake booster somehow. I don't know how cam size effects you brakes, if it does??? I just thought i read that somewhere on tech.
I tried a search, but no worky.
TIA
Old 05-11-2007, 10:57 PM
RandomHero's Avatar
Yea I have the same problem too. Switch to a hydroboost setup. You can get it off any 2500hd or avalanche or most SUV's. All you need is the hydroboost setup and the lines that run off of it. You'll need to T off of one line but otherwise it's bolt on.
Old 05-11-2007, 11:00 PM
silent1's Avatar
Yup, you lose a bit of vacuum with cams. Some have had luck with vacuum canisters "t'd" into your brake booster vacuum line. The best results seem to be from going to hydra-boost brakes system.
Old 05-11-2007, 11:01 PM
So what is the difference?
Old 05-11-2007, 11:13 PM
Truck has 71k on it. What about a bad master cylinder?
Old 05-11-2007, 11:15 PM
silent1's Avatar
This site explains hydra-boost systems fairly well:
http://www.hydratechbraking.com/products/
Old 05-11-2007, 11:21 PM
11 Second Truck Club
bluecajun5.3's Avatar
bigger duration cams pull less vacuum for the brakes.
Old 05-11-2007, 11:33 PM
RandomHero's Avatar
you don't have a bad master cylinder. It's just your cam. I have the SAME exact problem. I wonder if being on a stock Converter has anything to do with it?
Old 05-11-2007, 11:36 PM
silent1's Avatar
What makes you think a stock converter affects your braking?
^read my post!
Quick Reply: Cam vs. Brakes Question
