cammed 4.8 into a 62 nova
me and my brother want to put my 04 4.8 into his 62 nova can this be done ?its a strong motor and its cammed pretty much new .im putting a 6.0 for power in my truck .he needs a motor he had a old style 327 in it but it blew up racing it .this car has 533 gears in it and its tubbed i think it would be a fun ride if possible.
is this nova auto or stick? 5.33 gear and tubbed i am guess auto .... youll need transdapt flexplate adapter
i used this in another post ..... but here is my parts list that i needed for the swap other then the obvious(harness, pcm, and whatnot)
all summit numbers
HUP-HP3795 ---- Hughes flexplate adapter from ls1 >> oldshool trans/converter(cheaper then the 6.0 spacer and longer bolts)
TRD-4592 ---- Engine mount Adapters ----- only used the 'plate' and the hardware
ATM-2268 ---- oil pressure adapter ----- metric to npt adapter for the auatometer sender
ATM-2277 ---- water temp adapter ---- it is metric to npt adpater for the passenger side head plug --- had to drill it out so the sending unit for my autometer would work.
Needed custom radiator hoses....
ATM-2280 ---- for the head coolant to dump into the heater hose return
I used pacesetter 2001 truck headers, but im sure they make ls1 headers for that swap
cant think of anything else right now .... those engine mounts moved my engine forward .... you might be interested in just making your own when you want them.....
all summit numbers
let me know how it turns out. im thinking of pulling the motor in my 64 impala and swapping with a cammed 5.3 with all the bolt-ons. the new motors are just so reliable and i cant really afford a 6.0. btw, is it difficult to bolt a 5.3 to a powerglide?
