Cammed L33 questions!
Hey i'm swapping a L33/4L60E into a '95 240sx and was wondering what kind of power I can expect. As I said its a stock L33 with XER273 comp cam, LS1 car intake for now, injectors, longtubes with a tune. Also any of you guys that have a L33 whats the biggest shot (a.k.a. N2O) I can safely run I plan on spraying 150 but if I can do more I will. Also car should weigh 3150 with me in it what kind of times should I bee looking for the car to run it has 4.10 gears also.
2nd fastest 5.3 ECSB
if done right that car will be unmanagable
Tuning is the key. 150 shot no problem. I've been hitting my daily driver with 11lbs boost and the occasional 75 shot for a while...years. I'm making double HP over stock on the same dyno. Now I don't go WOT everywhere I go but your car weighs significantly less than my Z71
I'd think with the right suspension and all, assuming you can get the power to the ground, low 10's or better.
bbowerman
07-26-2015 10:57 PM
