Cammed my truck. Now having problems
Ok I have. 08 silverado that I just put a lot of money into, got the tsp224r cam package, circle d 3200 stall, lts, pry and 4.11 gears. My problem is that it runs alright but cuts out sometimes at all Rpms and it's hard to start. Started fine before the cam but not takes a good 5-7 seconds to fire up. Tuner said their was nothing he could do to fix those problems.
i just checked the check engine light and im getting codes for all o2 sensors, witch the rear two were turned off, and i do have a cam sensor code, the cam sensor was fine before the cam install, it shouldnt have got damaged in any way.
ya i checked the things i unhooked witch was o2 sensors, cam sensor, mass air, coil packs thats all i unplugged and they seem to be all good, also has new spark plugs witch are gapped at .060
did your truck have dod?
also, I still think its a cam sensor thing. Thats usually the only thing that could have gone wrong during a cam swap and causes a car to take a few seconds to start, THAT IS NOT tune related.
The cam sensor could tell you that the cam is "walking" which I doubt it is that or could be the DOD... I doubt it has anything to do with the cam gear needing to be switched... On an my motor swap with the LS2 I had to change out the cam gear to get rid of that code. So that is where the trouble codes that it is throwing will help us out.
