Cammed my truck. Now having problems
some one said its bc of the ls2 cam gear, but how would i fix this so it will start normal and not throw any codes???
Any ideas???
Also with all these need performance parts I put on and the tune done, the truck doesn't feel like it has any more power and isn't any faster
Any ideas???
I was told the later ls2 can gears and ls7 can gears are the same. And the 02 sensors wires are perferct and truck as low miles. So I'm guess it's in the tune some where. Truck still isn't starting worth a ****
I'm not blaming the tuner for the cam sensor problem. So I don't know where u mis understood that. I am te inexperienced one and that's why I made this post bc I didnt know where the problem was. I talked to the place that got me the cam sprocket and they did give me the wrong one. So I will replace it with the right one this weekend
I'm saying the o2 sensors could be from the tune or maybe anothe issue. I double checked them
I don't know what a crank relearn is
Once I throw the new ls7 can gear in, besides my problems being fixed will it run better to? Bc it cuts out a bit here in there through out the rpm range
