CAMSHAFT for LM7????????HELP???????
Old 12-23-2003 | 10:33 PM
SuthernFlames316's Avatar
Default CAMSHAFT for LM7????????HELP???????
I have a 99 lm7 5.3 and i am planning on putting a cam in it. I want to drastically increase horsepower and torque. I need suggestions for a cam that will give me badass results throughout the entire power band.
Old 12-23-2003 | 11:06 PM
Flyer's Avatar
218/224 .524/.534 112
That should be nice improvements all around. If you want to minimize computer tuning, get it ground on a 114 lsa.
A good list of your current mods will help better customize one. I would use that one on a stock truck through. I would get new springs and pushrods though. A higher stall converter would be nice too.
Old 12-23-2003 | 11:14 PM
FILE's Avatar
If you are tight on money, go with a cam of an ls1 engine. It's a nice imrovement over the weak 99 cams for the LM7's. You can one of these cams real cheap.
Old 12-24-2003 | 01:19 PM
ACDenali's Avatar
How much would the cam Flyer is talking about cost? $400 area?
Old 12-24-2003 | 03:31 PM
Banned
216/220 .540/.540 114
almost the same specs as mine but a little more lift and a bigger LSA, so it should idle a little smoother than mine.
Old 12-24-2003 | 03:40 PM
FILE's Avatar
I am not sure if comp makes that cam Flyer is talking about. Normally, they run about $350-400 new unless you want an ls6 cam. The cam does not have to be new. I got my cam with 3K miles and got a real good deal on it.
Old 12-24-2003 | 04:29 PM
BBLS1's Avatar
I Like Gold!!!
hey u might want to try a ls6 cam. Heard real good things about it.
Old 12-24-2003 | 04:40 PM
FILE's Avatar
That would be a good idea. He will have to with an aftermarket stall. That cam tends to make its power un upper rpm range.
Old 12-24-2003 | 09:01 PM
ACDenali's Avatar
Is there any cams available with considerable increase in power that I wont have to put a new converter in?
Old 12-24-2003 | 09:12 PM
10 Second Club
A friend of mine used to have a 216/216 114 cam in his 5.3 L truck, stock converter too. He really liked it and I thought it ran great.
Quick Reply: CAMSHAFT for LM7????????HELP???????
