can i reuse oil pan gasket?????
Old 02-04-2010, 09:02 PM
dry_kill's Avatar
got it fixed today, i tried to back of the bolts some and just tighten it as close to 18ft lbs as i could by feel. still leaked so i just dropped it some and put a bunch of rtv gasket maker where it was leaking from and it sealed it up.
Old 02-04-2010, 09:23 PM
PT's Slowest Truck
budhayes3's Avatar
Originally Posted by eallanboggs
The Block/Oil Pan/Timing Cover junction(Bank1 and Bank2 sides) is a spot where leaks can happen. GM has a procedure for aligning this stuff which is pages long and uses special factory tools. The timing cover bolts pull it against the block(you do have to make sure the cover seal is concentric with the crankshaft snout). You also have to make sure the front face of the pan is snug against the rear face of the timing cover. A bead of RTV helps prevent leaks at this junction, but I think you'll notice when you disassemble the motor for the first time there is no RTV used at the factory so it can be assembled without it and still not leak.
I know the tools of which you speak
Choda
01-23-2019 10:24 AM
Texas5.3_1251
03-05-2016 08:10 PM
SlvrSierra4.8
10-01-2015 09:39 PM
11MPG
09-10-2015 08:34 PM
Pimpinpete
09-08-2015 07:39 PM
Quick Reply: can i reuse oil pan gasket?????
