Can I run a f body water pump on--
Old 01-19-2007, 02:20 PM
ZR1 DREAMING's Avatar
This is what I am getting at can I run all the truck acc other then the truck pump with the ls6 intake, or do i need to use the f bod P.S, Alt. If I use the f bod alt bracket can I still retain the truck acc, even though they have different off sets.??
John
no man just the wp. Everything else is fine. The only other issue will be the alt. bracket, not pulley, you can make your own like krambo or get a speartech one from someone who got one before the stopped production. I have his links if you need or you can search his thread.
Old 01-19-2007, 02:36 PM
tdrumm's Avatar
If you put the truck water pump pulley on the car waterpump, you can retain all of your other truck accessories. To fit the LS6 intake when it is time, you'll have to trim the alternator bracket, and make a idler pulley relocation bracket.
Old 01-19-2007, 02:46 PM
exactly what I was referring to
Old 01-19-2007, 06:38 PM
Baltimore Whore
Mangled03gmc's Avatar
Ok thats what i need to know. Now this is cleared up for me. Thank for the help and clearing this shait up.
John
Old 01-19-2007, 06:41 PM
Banned
litreddevil's Avatar
i am running the ls1 elec.water pump and all i did was put 2 gasket on the pump and have been running that for sometime with on issue ask closet red neck i sent him pic of the set up
Old 01-19-2007, 07:01 PM
closet red neck's Avatar
Hell yeah. The eh2o pump will work just fine. I'm doing the cam, heads, eh2o pump and everything next month. All I'm waiting on is my getting my heads out of the machine shop and it's on.
James
ullose272
08-05-2016 02:05 PM
stealthperf
34
02-14-2016 11:35 AM
thunder550
10-08-2015 04:53 PM
Mossyoakglock
07-17-2015 08:30 AM
Gadgetized
07-07-2015 04:40 PM
Quick Reply: Can I run a f body water pump on--
