Can injectors fail?
Old 10-15-2007 | 02:15 PM
99/5.3w/hips's Avatar
Default Can injectors fail?
This morning no the way to work my truck started running on 7 cylinders basically. One wasn't getting any fuel. I got the infamous P0200 code letting me know it was an injector failure. Well I've had this problem in the past when I first wired up my 28# injectors and installed them. From either a wire coming loose or a small leak. I just checked all the wiring and it's tight as can be. I haven't started it to check for leaks but I figured if there was one this morning then the area around the fuel rails wouldnt still be covered in dust, they would be cleaner from the fuel getting on them. So my question is can injectors crap out and actually fail on you?
Old 10-15-2007 | 02:22 PM
thunder550's Avatar
High on diesel fumes
Yes, my dad had the same thing happen on his Tahoe. They replaced the injector and everything went back to normal.
Old 10-15-2007 | 06:38 PM
brodystruck's Avatar
I had to replace injectors on my truck....
Pimpinpete
43
12-22-2017 09:13 AM
Tydriver
45
10-23-2015 10:19 PM
OHsixLS3
09-25-2015 12:20 PM
jroctpb
09-16-2015 10:05 PM
