Can a stock 5.3L hold 600whp?
Old 08-17-2006, 07:58 PM
  #21
i think you could definataley do it if you put in some good rod bolts and rods and you definatley could do it. the thing i try to keep in my head is that the more fuel the better off i am. so i try to keep my fuel system over kill x10 .
Old 08-17-2006, 08:47 PM
  #22
dirt track racer 81's Avatar
pistons would have to be the weakest link..in my opinion..dont ask me how i know this..and i was just runnin 150 shot on a 5.3 when it let go
Old 08-17-2006, 09:31 PM
  #23
so can we say the weak link is the rotating assembly minus the crank?
Old 08-17-2006, 09:35 PM
  #24
you got it !!! that is definately the key parts to go bad past about 6600rpm with any detonation.
Old 08-17-2006, 09:36 PM
  #25
single digit dreamer
parish8's Avatar
the crank is definately strong but the other parts are not garbage. most people that run a turbo dont spin their motors that high so rods and rod bolts wont see as much of a load. the pistons will break in a heartbeat if you let it knock but keep a very close eye on the tune and they will take a lot of power too.
Old 08-17-2006, 09:41 PM
  #26
thats right, everything i read is true ITS ALL IN THE TUNE
Old 08-17-2006, 09:48 PM
  #27
quicksilverado's Avatar
Originally Posted by 02Vortech
should i keep the 4l60e and build it? or swap to a turbo400 (just get the computer reflashed for a manual tranny or w/e?
8.8" is hella cheap compared to a new gm 14bolt. and fits right into my s10blazer + moves the wheels out 1.5" on each side putting the wheels flush with the fenders and allowing for a wider wheel/tire.
what did the GM 14bolt come on stock??????
also weakest part of the 5.3L?
Just put a good after market posi unit in and it will hold alot of power.
Old 08-18-2006, 04:49 AM
  #28
Banned
litreddevil's Avatar
i say try it and let us know the out come
Old 08-18-2006, 12:27 PM
  #29
well said, run it till it blows then go 6.0
Old 08-18-2006, 06:38 PM
  #30
Banned
yep that is what you r doing hua turn them and burn them
Quick Reply: Can a stock 5.3L hold 600whp?
