can this work?
Old 03-09-2010 | 06:24 PM
youngbuck's Avatar
Default can this work?
can make my 93 4l60 floor shift transfer case, work with a 06/6.0 an 4l80? or am i screwed?
Old 03-09-2010 | 09:38 PM
BlownChevySS's Avatar
I believe the spline count is different from the 93 and 06 4l60's, so you would need to change the internals. There are some other things needed to do the swap too. Check over on silveradoss.com. A bunch of guys there have done them and could help you out with lots of great info.
Old 03-09-2010 | 10:03 PM
_zebra's Avatar
makes children cry
if'n i remember right, the NP241 has the same internals as one of the 3/4 ton floor-shift t-cases, you just have to swap the input shaft. the only thing... ain't the 4L80 a bit longer than a 4L60? you might need to lengthen your linkage
Old 03-09-2010 | 10:15 PM
budhayes3's Avatar
PT's Slowest Truck
If swapping the input shaft is all that is necessary, then this thread will be of interest to mr. youngbuck: https://www.performancetrucks.net/fo...d.php?t=368971
Old 03-09-2010 | 10:22 PM
_zebra's Avatar
makes children cry
i didn't look too much into it, but i believe i remember seeing where somebody on FSC did that
Old 03-10-2010 | 09:56 PM
youngbuck's Avatar
tht would b awesome. thanks 4 the link also. what about my harness tho? how can i make tht work? the harness is setup 4 push button 4wd.
shawn96gmc
05-17-2016 04:15 PM
Stainless Works
04-10-2016 04:34 PM
Stainless Works
08-04-2015 12:56 PM
atxlt
07-20-2015 11:06 PM
Nimoryan
07-05-2015 03:50 PM
Quick Reply: can this work?
