Can you install heads and head studs with out removing the engine.
Old 10-06-2008, 06:44 PM
NegraRCSB2X4auto's Avatar
Default Can you install heads and head studs with out removing the engine.
I'm trying to get everything together to install my heads and cam.I called ARP and asked them what Part number i needed for head bolts or studs. They told me they didn't have a specific part number for them. So I asked for the ls1 head bolt but im not sure they'll fit:
bolts 1343610
studs:234-4317
header bolts:434-1301
Does anyone know for sure the part #'s for sure OR the bolt lengths and thread size?
Also If i get studs will i be able to get the heads on and off with the engine in the bay?
Old 10-06-2008, 06:54 PM
High on diesel fumes
thunder550's Avatar
Dunno about the part numbers, but I've done a head swap in the truck with head studs before.
Old 10-06-2008, 07:03 PM
okay so I should not have any clearance issues installing the heads on the studs. Good to know.
Old 10-06-2008, 09:32 PM
thunder550's Avatar
Now that I think about it, I can't remember if I pulled the studs or not...I may have put the studs in after the head was set on and lined up.
Old 10-06-2008, 09:45 PM
PT's Slowest Truck
budhayes3's Avatar
I remember reading here that the heads won't slide over the studs on our trucks. The heads will have to be placed on the block first, then the studs must be screwed in, and vice-versa for removal.
Old 10-06-2008, 09:50 PM
Baltimore Whore
Mangled03gmc's Avatar
Just a ??? why do you want to stud it??
John
Old 10-06-2008, 10:20 PM
built408's Avatar
you have to set the heads on first, then install the studs, been there done that..
Old 10-07-2008, 06:50 AM
John
security...If ever get the urge to up the boost. If I don't get my desired times I'm going to spray it. When it blows I'll just bore it and that will be one less thing I'll have to worry about buying.
Old 10-23-2008, 05:29 PM
bad cutt's Avatar
I installed the heads on my motor with the studs already in it wasn't even tight they slid right on.
Old 10-27-2008, 01:33 AM
I have studs and have had the heads off 8-10 times without having to pull the studs out of the block.
Quick Reply: Can you install heads and head studs with out removing the engine.
