Carb Hat
Carb Hat
I gotta Vic Jr that should be here in a week or so. I'm going to run 4150/4500 4-barrel throttle plate and trying to figure out what route I'm going to go out running a carb hat to a 4 in pipe or just run an open element filter which i do not want to do. So far heres what Ive found for a carb hat. If i do go with this one it will be the black one. For you guys that have gone this route what have you done? http://cgi.ebay.com/ebaymotors/Carb-...spagenameZWDVW
High on diesel fumes
If you're interested, I'd sell you my setup above with the throttle body, Lokar throttle cable ends, and carb hat for $560. TB is Edelbrock 3878, 1.75" bores, 1000 cfm and includes the IAC and TPS. I'd send you my throttle and cruise cables as well (since I cut the ends to put the Lokar cable ends on) if you would send me your uncut ones in return.
Skip Fix
22
07-09-2016 07:08 PM
