Carburation Swap
You'll need a fuel pressure regulator to step the fuel pressure down to 5-7psi. You will have to swap the intake, distributor, and add a carb. You should be able to adapt the linkage, and it should be very easy if you have a little experience messing with smallblocks. You should be able to get in knocked out in a day easy. Later
Dave
Dave
GrooveCityZ71
08-31-2015 12:05 PM
superchomper2003
08-26-2015 09:39 AM
