Cat Delete Y pipe
Originally Posted by Zick
I wonder if it has all 4 O2 sensor bungs? Even if it does how would the computer react to the rear readings with out the cats. I realize that if there are only fron O2 bungs I would have to use O2 sims or have them turned off with tuning.
Any insight?
Originally Posted by j's01silverado
I have not seen the either of the y-pipes in person. But you would definately have to turn off the rear o2's or get sims.
I plan on having a tune done in a couple of months and will have the rear O2's truned off but I may install a y-pipe before then.
Originally Posted by KY_BOB
Any suggestions on where to get sims? How expensive are they?
I know this is an older thread but I was wondering if anyone has tried this Y-pipe. If so is it flattened out like a factory pipe or not? I would assume the GM 15045260 is flattened out like a factory Y with cats.
Any insight?
Any insight?
As a matter of fact, I have just got one delivered. It has all 4 bungs, and is not flattened. The only thing is that the loose flange is backwards and can't be flipped on this one. Someone would have to cut and re-weld the pipe...DOH
May fix it, may return it, don't know yet.
