Cat Delete Y pipe
Old 05-16-2006, 08:25 PM
  #31
Leroy_454's Avatar
Glad to see it is working well. Looks like a good piece. Is the pipe size a little bigger on the jegs pipe, or are they the same?
Old 05-16-2006, 09:06 PM
  #32
kbracing96's Avatar
It's 2.5 inch, which is the same as stock but it doesn't have the squashed area in the cross over that the stock pipe has and it is mandrel bent.
Old 05-16-2006, 09:14 PM
  #33
Zick's Avatar
Originally Posted by kbracing96
I'm running the Jegs Y-pipe on my truck now.
Wow, that looks a lot better than I thought it would.
Old 05-16-2006, 09:45 PM
  #34
kbracing96's Avatar
Its a nice piece, I was very impressed
Old 05-17-2006, 04:54 PM
  #35
o2man98's Avatar
What is the part number on the Jegs-Y pipe and how much does it run?
Thanks
Old 05-17-2006, 07:32 PM
  #36
kbracing96's Avatar
http://www.jegs.com/webapp/wcs/store...tegoryId=29235
PN 555-31004 is what I have.
Old 05-23-2006, 11:50 AM
  #37
KY_BOB's Avatar
Interesting.
I had looked at this before. They have now added a disclaimer to the discreption that makes it sound like it won't fit my truck
1998-2002 Silverado/Sierra C/K15-1/2 ton pickup w/4.3L excluding CA., 1999-2000 Silverado/Sierra C/K15-1/2 ton pickup w/4.8L, 5.3L, excluding CA. All 2-3/4'' single flanged exhaust after dual converters only
555-31004
Does not fit 2000-02 models with original equipment y-pipes with flat spot after the drivers side O2 sensor and just before the y-junction
Old 05-24-2006, 10:18 AM
  #38
KY_BOB's Avatar
You didn't have any issues with the fit? According to the disclaimer it shouldn't fit. I'm assuming that you have the same Y-pipe that I have, I know that a '02 Silvy 5.3 and '02 AV 5.3 are the same.
Old 05-24-2006, 10:41 AM
  #39
kbracing96's Avatar
Nope, it's on my truck right know. Well, i guess the only issue is you can't put the pass side rear O2 sensor in, but I didn't use either of the rear O2's (see the second pic)
Old 05-24-2006, 11:10 AM
  #40
KY_BOB's Avatar
Maybe that's what they are talking about but I don't even see why it even comes with rear O2 bungs. Rear O2's are worthless without cats
FlowmasterMufflers
11-24-2015 01:00 PM
TrickTurbo
09-23-2015 08:41 PM
JordanH
09-12-2015 12:02 AM
sTNT971
09-11-2015 02:38 AM
chvy=power
09-08-2015 11:06 AM
Quick Reply: Cat Delete Y pipe
