Which Catch Can?
I used the CCA Catch can in conjunction WITH the LS6 valley cover. I feel the CCA is the best designed and built (even though it is so simple). Do a search for CCA Catch Cans and compare the internal construction to the others and make your own assumptions. The picture below was a test and fit. I have since cleaned up the hoses and used pretty red hose ends.
After about 1-2K miles IIR. Even with the LS6 Valley cover, I still pull oil vapor and moisture out using the CCA can. I really like the way it works!
You could look at this one its not as pretty as the others but for half the price couldnt be too bad and should work ok. http://www.jegs.com/i/JEGS/555/52205...oductId=763433
Thinkin bout a catch can or possibly 2 myself... also was wanting to save a few bucks, is there anyway to add a filter or screen or something to make the hollow ones more effecient?
I have an AMW but the elete engineering catch can would be as good...
http://www.eliteengineeringusa.com/
