Catch Can Revolution!
I have had a Mike Norris catch can in my truck now for about two (2) years after I installed a new motor. Have changed the oil several times and drained the catch can but only got water.
I was told that it was condensation coming out instead of water. But never the less it wasn't oil.
As I was working on the engine this past weekend I looked to the catch can to see how it was draining and if it still had only water coming out. The drain **** was locked shut so I took the can off of the alternator bracket to see what the problem was. As I unscrewed the bottom of the can where the drain **** is, oil came gushing out! I would say that almost half of the can was full of oil and water.
So now I know the catch can works, but why would it only draw moisture (water) thru the drain **** and not oil? Why would water, or condensation, come out and not oil? It had oil in it for sure, dumped it right on top of my sneakers! Think I might just plug the bottom of the can and just unscrew the bottom the next time I check it.
Your thoughts?
Chad
Your thoughts?
Chad
Not sure, didn't pay that much attention to it between oil changes. Sadly my transmission took a poop while racing a Pontiac G8. So I am in the midst of removing the tranny, changing the intake and cam, new starter, new crank pulley and waiting for my Monster Transmission to show up to change it.
Also changing my driveshaft and rear end yoke, they suffered catastrophic failure during the race!
Chad
Chad
I think the drain **** got cocked over or bent at some point during the installation of the CC. I could only get a turn or two out of it to let any fluid out. Might put another drain **** in it or small valve.
You are correct, water is heavier and probably the reason water was coming out first.
Chad
Chad
