Change in plans - no LQ9, keeping stock LQ4 instead
Old 04-19-2006, 02:27 PM
vanillagorilla's Avatar
*****! I say go with the LQ9. How much boost are you planning on running with the LQ4 anyway?
Old 04-19-2006, 03:09 PM
High on diesel fumes
thunder550's Avatar
SHUT UP!! I DO WHAT I WANT!!!
Old 04-19-2006, 03:11 PM
thunder550's Avatar
Todd, come up Friday and go racing. I'm going down with Ryan (had the El Camino at dyno day).
Old 04-19-2006, 03:30 PM
thunder550's Avatar
Probably 10-12psi max. If you want to foot the bill for the swap I'll do it.
Old 04-19-2006, 04:11 PM
That's a negatory on Friday. I'm working late and I'm convoying up with the boys on Saturday.
As for the bill: A built 80E, new cam, new pulley, and a 6.0L....what's another $700.
Actually, you know what, go with the LQ4 and use the extra money for some better valves and/or do some minor polishing and bowl work.
Old 04-23-2006, 04:48 PM
OrlandoFL4.8's Avatar
I kind of wish I went I with the lq4 and just threw on some ls6 heads to up the compression ratio for NA performance, than if I wanted to run boost, just throw on the 317 heads to lower it. Now if I want to lower it, it seems my only options are to get dished pistons because I have heard stacking or getting thicker head gaskets is not a good idea.
Old 04-23-2006, 05:42 PM
thunder550's Avatar
Yeah, I think I will be happier long-term with the LQ4, seems like there are always ways to raise compression but it's hard to lower it.
ARC
57
02-21-2022 10:54 AM
OHsixLS3
12-27-2016 09:30 AM
GrooveCityZ71
08-31-2015 12:05 PM
Suburban2500
07-19-2015 04:50 PM
ALynch
07-06-2015 09:49 AM
Quick Reply: Change in plans - no LQ9, keeping stock LQ4 instead
