Changed plugs now it misses.
Old 03-27-2007, 10:23 AM
ZR1 DREAMING's Avatar
Gap @ .035 and re-check all plug wire connections at plugs and coil packs.
Old 03-27-2007, 05:58 PM
GTOsRamairSilverado's Avatar
Originally Posted by LOGICUSER04
I just finished changing my plugs on my 5.3, and now it misses under load. It does not miss when it is at idle just when it is under load (taking off from stop). I used the NGK TR 55s and reused the stock wires. And i gapped them to .055.
i had the same problem with my truck and i used the same pulgs tr55's. I took the plugs out and tested them with a digital multimeter and found that i had 3 bad plugs. i took them back to oreillys and they exchanged them. put the new ones in and the truck worked fine. You might want to check the plugs. mine didnt physically look damaged but they were not working.
Old 03-28-2007, 08:35 PM
LOGICUSER04's Avatar
How do u check the plugs with a multimeter.
Old 03-28-2007, 08:50 PM
13 Second Truck Club
bigbadwolf54's Avatar
use an ohm meter and check from the electrode (the pointed tip on the bottom, NOT the ground strap that you adjust gap with) to the tip(where the wire clips on) ...should be a resistance , if none or higher than the others youve got a bad plug.
Old 03-29-2007, 09:17 PM
yeah do it the way bigbadwolf says
I think you have a bad plug.
FYI you can also check your wire the same way!
good luck!!!
ss454327
10-17-2015 03:43 PM
Noah Burns
09-07-2015 05:50 PM
1bdbrd
08-23-2015 03:24 PM
713truck
08-18-2015 09:32 PM
rojeho
08-08-2015 07:20 PM
Quick Reply: Changed plugs now it misses.
