changin o ring for oil pump
Old 06-26-2010 | 02:25 AM
Bumpers's Avatar
Default changin o ring for oil pump
I'm wondering I'm about ready to stick my 6.0 in my truck. Its a stock 6.0 with like 71k on it but I'm wondering if I should go ahead and change the o ring or just leave it be. I haven't ever done it before and I'm scare of messing with the oil pump. What do you guys think?
Old 06-26-2010 | 02:28 AM
AJII's Avatar
Don't do it. We tear enough stuff up as is...that's just asking for it.
Old 06-26-2010 | 02:31 AM
Well if u already have it out the truck id change the oil pump and the timing chain to be safe.
Old 06-26-2010 | 11:32 AM
brent5631's Avatar
Usually the only time it gets messed up if when you F*** with it. Unless your changing the chain and everything I wouldn't worry about it.
Old 06-26-2010 | 11:37 AM
KySilverado's Avatar
Ain't broke..... don't fix it.
Old 06-26-2010 | 11:39 AM
JakeBrakeIH's Avatar
I'd leave it be, just run it.
Old 06-26-2010 | 12:48 PM
Tootall's Avatar
Leave it alone. It's not even touched when you do a cam swap.
Old 06-26-2010 | 01:48 PM
Bumpers's Avatar
Thanx fellas that's what I wanted to hear
I noticed when I put the cam in that the timing gears and chain and everything look heavier duty than what was in my 5.3
Old 06-26-2010 | 02:22 PM
AJII's Avatar
Did later year LQ4s get the ls2 chain?
Old 06-26-2010 | 02:29 PM
Bumpers's Avatar
Idunno but mines a 06 and it has the same connecting rods as a lq9
