cheap 42lb injector mod.
Old 04-09-2010, 10:20 AM
lsxmalibu's Avatar
Default cheap 42lb injector mod.
42lb injectors off ls3's can be found for $50-75 for a complete take off set, they are way to short, I found spacers but they were backordered and was told the bottom is too small. I ended up getting a $5.00 piece of brass tubing, inside diameter fits the injector perfect, the tube is 5/8" outside, so I drilled the bosses in the intake out to that size, put a little sealer, then tapped them in, then put JB weld around the outside.
Old 04-09-2010, 10:27 AM
MikeGyver's Avatar
Good find! What is the ID of the tube? Or the wall thickness, if that is what is listed on the label? And where did you buy it?
Old 04-09-2010, 10:57 AM
lsxmalibu's Avatar
not sure the id, its thin, but I cut it with a hacksaw and it didnt distort. Local hardware store, next to the steel-alum stock.
Old 04-09-2010, 11:02 AM
makes children cry
_zebra's Avatar
that's pretty slick & looks good, too
Old 04-09-2010, 11:07 AM
Banned
max1's Avatar
whats the part number.. might get some for ls2 intake
Old 04-09-2010, 11:08 AM
Registered User
racinjason5074's Avatar
thats cool
Old 04-09-2010, 11:40 AM
lsxmalibu's Avatar
stock number 143....
dont drill the plastic intake all the way down, if you leave a little plastic on the bottom runner side it acts as a "stop" when you push the bushing in.
Old 04-09-2010, 01:54 PM
blownerator
BlownChevy's Avatar
With the injector that far up the pipe and out of the airstream you will most definitely have tuning and wall wetting issues.
Old 04-09-2010, 02:46 PM
lsxmalibu's Avatar
its no different than the aluminum injector spacers you buy from FAST
Old 04-09-2010, 02:48 PM
hirdlej's Avatar
I hate when my walls are wet In all seriousness, how far recessed is the injector nozzle from the intake port on the manifold? If it's not too bad I'd say run it
Quick Reply: cheap 42lb injector mod.
