Check Engine code reads misfire in cylinder #7
i hope not!!
i just swapped the plug and plug wire that was on cylinder 7 to cylinder #1 and im about to bring it to the auto store to check the code to see if it switched to #1 instead of #7 and hopefully it did so ill kno its either the plug or wire ill be back in 20 min. and ill update thanx for all the help everyone
did you test it/them?
stick a screw driver in the boot of the spark plug wire and see if there is any spark when you try to start it. if it does have spark, its a good chance that the coil is fine, if it doesnt spark i would think that the coil is bad or the spark plug wire is bad. replace the wire first. test it again. if its still not sparking, then its your coil. and make sure the connections to the coil are good and have nothing wrong with them... thats my best guess to help with the situation. if anyone has any more info, please add on or correct me if im wrong
why?
jus got back from advancedauto and even after swapping the wire and plug from #7 to #1 the code is still reading cylinder #7 misfiring. I got the guy to clear the code out and it has yet to come back on. if it comes back on im gonna swap coil packs with another cylinder and take it back to see if its still reading #7 and then go from there. next step would be injector i would imagine and after that valves
