Check Engine code reads misfire in cylinder #7
Old 01-04-2010, 11:40 AM
  #41
Baltimore Whore
Mangled03gmc's Avatar
Glad to hear you fixed the prob.. I would of thought number 7 cyl being dead as the last last thing. It is uncommon for one to pop in a NA set up that is virtually stock(unless your sig is not up to date)
Old 01-04-2010, 08:35 PM
  #42
acethedragon's Avatar
had this same problem with my truck a while back. #1 cylinder misfire. changed plug, wire, and coil with no change. coworker made the comment bout the injector going out. ended up changing the whole intake out for a tbss intake w/90mm tb and ls2 injectors. havent had a problem since.
tweeder
09-18-2015 11:02 PM
GMCtrk
38
08-09-2015 08:50 PM
Ketis
07-23-2015 12:37 PM
EscaTruck
07-20-2015 11:42 AM
bsgiffor
07-19-2015 11:14 AM
Quick Reply: Check Engine code reads misfire in cylinder #7
