Check Engine light
Check Engine light
So recently my light has came on and its throwing a code for the MAF sensor. What can be the problem? I dont know much about checking that part? All wires seem to be good also.
well i just took a look at the sensor and there seems to be no sign of oil. but i noticed the yellow wire going to the part that connects to the MAF has a slight little slit in it and shows some of the inside wiring. My MAF is also unscreened but has been since I have gotten the truck and i've never had any problems with it. Any other suggestions? Also are the MAF's from these kind of trucks the same as to the 1999-02 camaros? I may be able to swap the entire MAF if so just to see how it'd react
yea go the cheap way first and go to the parts store and pickup a can of CRC maf cleaner like said above, spray it down and let it dry, do it a couple of times.. i have seen many cars and trucks have codes and do that and runs better than new! if that dont work id get another and leave the screen in it, unless your makn lots of power theres no need to take it out bc it can make your fuel trims and air ratio kinda go whack sometimes.. jmo tho good luck with it man
Moderately Differentiated
That could be corrosion in your volt wire. If that slit in the insulation bothers you enough cut it open and make sure the copper is good. If it isn't, make it good and seal up. Unplug battery for 5 minutes and try again. (remember it may run rough at first with battery unplugged for 5 minutes)
tweeder
09-18-2015 11:02 PM
GMCtrk
38
08-09-2015 08:50 PM
bsgiffor
07-19-2015 11:14 AM
