Choosing the right cam
Old 08-21-2007, 10:14 PM
03GMC's Avatar
Originally Posted by nightrunner
TSP= texas speed and performance, a sponsor listed to the right>>>>>>>>
if ya got the cash id get the maggie, but with it you'll need a trans sooner or later
Ok I found it. Thanks.
So is this the order I should do the mods in?
Shift kit and servos
Headers
Converter
rear end
cam
Or should I just do the trans mods and get a cooler then buy a maggie? I just got a pretty well paying job and will be able to buy one in a few months at most.
Old 08-22-2007, 09:06 AM
03GMC's Avatar
Headers
Converter
rear end
cam
Bumpo
Old 08-22-2007, 09:59 AM
TXsilverado's Avatar
everyone has their own method of getting there. i was a full bolt-on 5.3 without a cam, then ran a ls1 on the stock cam for a good while before i made the leap. i waited alot longer than most guys for the cam.
most go out and get an intake, full exhaust, converter, cam and gears and put down great times.
Old 08-22-2007, 03:18 PM
03chevy5.3rcsb's Avatar
I've done alot of research on this subject, as I am ready for a cam swap. After reading threads for days and books and talking with tech at thunder racing, I've decided on a tr220-114. If you want alot of lope and dont have to worry about smog go with a tr220-112. 224 is a big cam and unless you've got the mods to support it it'll probably be a bit sluggish on the bottom end especially without a stall. with a 220 you can prob get away with a tbsc and be ok. of course everyone has very different opinions on cams. this is all my opinion. they are also exhaust happy cams, so let it breath as much as possible
Old 08-22-2007, 03:21 PM
Oh, and I'll be going with a Yank 3200 , not cheap but almost stock size which is better for a dd
Old 08-22-2007, 04:15 PM
RoosterMcCandles's Avatar
3200 almost stock size? A stock converter doesn't stall anywhere near there...
Old 08-22-2007, 05:02 PM
almost stock diameter meaning it holds more fluid, less heat.
Old 08-22-2007, 05:06 PM
Mr. Obvious
nightrunner's Avatar
im guessing he means physical size as in 10.5'', 11'' etc.
Denali08
08-09-2015 04:34 PM
sTNT971
08-07-2015 09:05 AM
steves86ta
07-28-2015 10:21 AM
FlowmasterMufflers
07-22-2015 01:29 PM
FlowmasterMufflers
07-17-2015 03:26 PM
Quick Reply: Choosing the right cam
