clogged cat maybe?
clogged cat maybe?
my truck (03 model sierra) threw all three of these codes at the same time today P0131 P0137 P0151, or other words 02sensor low voltage circuit on Bank 1 sensor 1 and sensor2 and Bank 2 sensor1..........what could have caused this?
PT's Slowest Truck
A clogged cat will hold the engine back, from what I've seen on the GM's usually the engine won't rev past 4000 rpm, and will misfire. You'll feel a power loss when trying to accelerate. I'm not aware of a clogged cat being associated with those codes. Low voltage on both banks means that the O2 sensors on both sides are reading too much oxygen. I'd be checking for a vacuum leak or air intake leak allowing unmetered air in.
...well after thinking about it, it all happened in extreme acceleration,so im thinking that not enough fuel was getting there and that tripped the codes, but still it doesnt really make sense because my truck is pretty much all stock
FlowmasterMufflers
11-24-2015 01:00 PM
